Patient move themself in wheelchair?
cphilpottX22K5
cphilpottX22K5
[ FlexSim 23.1.2 ]
I hope this is a simple question. I have patients that are low acuity but still need a wheelchair. When they enter or exit the department, I want to simulate them moving themselves in the wheelchair. Is it possible to do this without staff?
Paula_LG
Hi Chandler,
To do that, you need to change the Wheelchair's properties so that it is allowed to travel and use a Travel activity in Process Flow where the Executer is the Wheelchair.
I hope it helps!
Jeanette_Fullmer
Hi @Chandler, was Paula LG's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
cphilpottX22K5
Super interesting. I haven't looked at the travel activities so I will have to give it a try and come back here to accept the answer if it works as I'm hoping it does.
cphilpottX22K5
I have not had time to try to apply this yet. I believe that the answer Paula gave is sufficient but haven't tested to see if it solves the problem as desired. I have not accepted the answer but if you're ok with that being auto accepted then I won't mess with it.
