Parameter Value Using Global Table?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I am trying to enter group member count using global table input as below:
I am facing some errors. It seems I can't enter value from global table.
If it is not possible, what is the best way to import group count from excel?
Thank you!
moehlmann_fe
To set the value of a parameter use the following syntax instead.
Model.parameters["ProviderCount"].value = Table("Input")[1][1];
This should work as part of the 'Post Import Code' in the Excel Interface.
In future, if you mention that you are "facing some errors", please attach a screenshot of those (as much information as possible, in general).
rajankur6494
Thank you! @Felix Möhlmann
Sure.
