Pallet stacking does not work well.
kato_masashi01
kato_masashi01
[ FlexSim 24.0.4 ]
I have a question about the pallet stacking behavior.
I have a model file created in FlexSim23 and opened in FlexSim24,
When I change the pallet contents to pallet stacking
The palletized pallet content looks like the image below.
Could you help me with this issue, please?
Thank you!
moehlmann_fe
The shape factors of the pallet object have changed between versions and the pallet stacking code assumes the new ones.
You can just replace the pallet in the flow item bin with a copy from a fresh model in version 24 to make it work correctly. You might have to set the stacking logic again after replacing the old node.
kato_masashi01
Thank you for your response.
The node was rewritten and successfully palletized.
Thank you very much.
