[ FlexSim 24.1.0 ]
I'm working on a model in which the transporters feed the machines.
Right now I need to calculate the time the transporter takes to load and unload the queues between the change of recipes, i.e. the setup time.
I have a sub process flow to get off the not needed materials and another to load the queues with the needed materials that works both in the middle of a recipe and at the end.
I have putted the transporter state "setup" only in the sub process flow "not needed materials" which is wrong.
Can anyone help me somehow to separate the load material in the middle of the recipes and the load materials between the recipes so I can have the setup times correctly?
I hope I explained it well
Thank you in advance 🙂
