OptQuest Error: Error in constraint equation
maryamh11
maryamh11
[ FlexSim 24.1.0 ]
I set up an integer parameter in the parameters Table and when I want to use it in constraints or objectives in the OptQuest optimization panel, I get this error " Error in constraint equation".Is the bracket a problem [param1] or anything else?
joerg_vogel_HsH
@Maryam H2, can you provide informations like constraint statement code, screenshot of error, perhaps an example model? Thank you.
maryamh11
@Joerg Vogel The constraint is [Order_Quantity_1PR]>=[PR_1_D]. both [Order_Quantity_1PR] and [PR_1_D] are parameters in Parametr Table. when this constraint is active I get the error below:
but if I change the constraint to something like this [Order_Quantity_1PR]>= 400, i do not get the error any more. both parameters are integer and the LHS of equation sets a value in a Global Table.
Do you know what would be the cause of getting this error?
Jeanette_Fullmer
Hello @Maryam H2,
The constraint limiting value needs to be a number. You can rewrite your constraint to something like this.
[Order_Quantity_1PR]-[PR_1_D]>=0
Optimizer constraints.fsm
logan_gold
Hi @Maryam H2, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
