@joerg_vogel_HsH
I apologize for the miscommunication. Actually, this is already a reduced model compared to my full project. When using the Agent System, my main issue was linking it to a group of operators whose quantity changes at every reset. This happens because I am running simulations with the Experimenter to analyze the impact of scenarios that vary the number of operators. For this reason, I need to create a parameter to control the number of operators. However, when I select a group in the agent page and reset my model, only the first operator remains allocated.
My objective is to have a configuration that provides the most realistic representation of the project, ensuring that no operator walks through another. Therefore, I need to evaluate the maximum possible number of operators in the workstation, comparing the results of productive capacity and productivity obtained in each scenario.
As an observation, the Experimenter is not included in this demonstrative model, only in the final version. However, if you think it is necessary, I can insert an example here.
Thank you for your patience and support.
