[ Flexsim 17.1.6 ]
Hi All,
I have a module where I have added an OnStateChange dll function to an object in the library. This function worked good and did what I wanted, until I used a wait for event in processFlow where I am waiting for the OnStateChange on the same object. It looks like the wait for event in the processFlow creates a flexscript node in the behaviour node of the object in the model:
I think this causes that the dll function in the library is no longer called ( below the dll function in the library )
How can I fix this? Manually copying the dll node from the library over the flexscript node in the model works, but that then needs to be done for each object in the model.
Thank you for any help,
Patrick
