Display Name of Objects on Bar chart using Statistics Collector
arunTTT2P
arunTTT2P
[ FlexSim 17.2.2 ]
Is it possible to change the display name of an object in a utilization graph made by the statistics collector ? This option was there in the legacy bar chart.
displayname.fsm
Arun KR
dawid_dabal
You can add column to a StatisticCollector/Data recording, for example Object_name, write there "Processor1" and choose its value as a Bar title in your chart.
9078-psc-1.png9077-displayname-dd.fsm
All the best,
Dawid
mischa_spelt
Hi Dawid. In principle your solution is fine, but it is not very flexible if you want to add multiple objects to the same statistics collector. I would suggest that you don't enter "Processor1" for the column value, but
data.rowValue.name
Don't forget to et the Storage Type of your Object Name column to "String".
