Offset Travel not working for Transporter loading a Rack
clairekruppGhafari
Message 1 of 8
clairekruppGhafari
[ FlexSim 19.1.1 ]
transporter-offsets-load-unload.fsm
I have a transporter loading parts into a rack. I'm using an AGV network so that I can control traffic using control areas. I want to show offset travel for load/unload but when I pick that option and then save and reset, the offset travel is not happening.
I tried "use navigator for offset travel" but that gives me an exception error.
Later I was trying various options and the offset movement started happening!
Turns out if you save after applying the "travel offsets for load/unload tasks" it does not work, but if you re-apply the same setting and DON"T save, then it works fine!
Replies (7)
Message 2 of 8
clairekruppGhafari
For a temporary fix - is there a FlexScript command to turn on the offset travel for the transporters On Reset?
Message 3 of 8
clairekruppGhafari
Found it:
setvarnum(Model.find("Transporter_AGV"), "useoffsets", 1.0);
But it doesn't work if you put it On Reset. Has to be On Start or later.
Message 4 of 8
joerg_vogel_HsH
Why don't you build the path system with Network Node objects. You can insert extended connections to let the Taskexecuter resume his travel at a different network node. network-node-useoffsets.fsm
Message 5 of 8
clairekruppGhafari
Thanks @Jörg Vogel. I did think about using network nodes, but I did not know how to insert extended connections.
Message 6 of 8
clairekruppGhafari
@Joshua S is this a bug with the AGV network?
Message 7 of 8
clairekruppGhafari
@Jörg Vogel do you know if a similar thing can be done with AGV Control Points?
Message 8 of 8
joerg_vogel_HsH
AGV Module uses travel to objects.There was no intent for an offset travel.
Update: since FlexSim 20.1 offset travel is a feature of AGV Module.
