メッセージ1/8
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- パーマリンクを表示
- 印刷
- 報告
[ FlexSim 19.1.1 ]
transporter-offsets-load-unload.fsm
I have a transporter loading parts into a rack. I'm using an AGV network so that I can control traffic using control areas. I want to show offset travel for load/unload but when I pick that option and then save and reset, the offset travel is not happening.
I tried "use navigator for offset travel" but that gives me an exception error.
Later I was trying various options and the offset movement started happening!
Turns out if you save after applying the "travel offsets for load/unload tasks" it does not work, but if you re-apply the same setting and DON"T save, then it works fine!
解決済! 解決策の投稿を見る。
