objets axes not appearing
djami_zinedine
djami_zinedine
[ FlexSim 24.0.0 ]
hello
i have this issue when i cant rotate or change the size of objects from the 3D model
i could do it before but since now, the axes are not apearing
you can find an example model in the description
1712648180457.pngvisuel problem.fsm
joerg_vogel_HsH
Please check if this option is inactiv:
https://answers.flexsim.com/answers/162128/view.html
djami_zinedine
thank you for your answer, i followed your instructions but the the box was checked
i just got the info that i can use the touch G and it makes the axes appear again,i must of touched it sometime, its working perfectly now
thank again
