Objects not clickable
HKSim
HKSim
[ FlexSim 24.1.0 ]
After making some changes to "release staff" module, objects are not clickable any longer. This may be associated with the field "Assign Released Resource to" in the module. "0" keeps appearing even after I delete and reset/rerun the model. Could you help resolve this issue? Thank you.
moehlmann_fe
Similar to your other question, I don't think anyone can really help here without seeing the model. Something must have broken internally in the activity.
HKSim
Could you explain why I can't change "0" in the field, "Assign Released Resource To"? Even though I delete it, it keeps appearing.
moehlmann_fe
No, as I said, the activity seems to be broken. Normally, you should even get an error message telling you that strings (text) are not allowed in this field.
Does it work if you replace the activity with a new one?
Ben_WilsonADSK
"objects not clickable" feels like a graphics issue:
Graphics Compatibility - Common Problems and Solutions
Is there any chance the behavior change is related to something your operating system did, an update or something, and the fact it happened around the time of a specific modeling change is just a coincidence? It may be worth testing in a new model to see if the issue is there. If so it is a system issue, and you can use the article at the link above to find a solution.
Jeanette_Fullmer
Hi @HK,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
