Need help with Operator sequence
jlandrum4QA5V
jlandrum4QA5V
Community Visitor
Community Visitor
Ok so I'm very new to FlexSim and I want to test the viability of a weld line restructure. I need the Operator to follow a standard work sequence. (Sub cart- Sub jig- Main cart -Front jig- QC- Queue1) Currently the operator goes to first available workstation. Any help or insight would be appreciated.
moehlmann_fe
I would push the various tasks to a Task Sequence list (partitioned by object) and pull/dispatch them in the wanted order in a Process Flow.
jlandrum4QA5V
Community Visitor
Community Visitor
Thanks that works but is there a way to make the Operator to continue the process instead of waiting at Queue1? In a real-world scenario, the operator would continue to load parts.
moehlmann_fe
Saying that the operator should follow a sequence implies to me that he should wait for the next task in the sequence and not repeat a different one. That would mean the operator should prioritize certain tasks. Which you can achieve in your original model by giving the task different priorities (higher for later tasks).
jlandrum4QA5V
Community Visitor
Community Visitor
Could I add a decision to the process flow that sends the Operator back to the sub cart if the QC Queue is empty?
moehlmann_fe
Yes, you can add a maximum wait time to the Pull from List activity and send the token to a different connection when it elapses.
jlandrum4QA5V
Community Visitor
Community Visitor
That works great! Thank you so much for the insights!
