Need help with Batch Process
brandon_tondreault
brandon_tondreault
[ FlexSim 7.7.4 ]
I am trying to figure out how to create a batch process where 15% of the time , the batch goes to Port 2 and the rest of the time goes to Port 1. By doing 'By Percentage' it only moves part of the batch to Port 2 and not the whole batch. Can you help?
philip_diem
Maybe you could try this. It`s not elegant but it works:
Put a numlabel on the queue that produces the batch and call it e.g. "path"
On the OnEndCollection Trigger you just write this:
// Produce a uniform distributed random number between 0 an 100
double randomNumber = uniform(0,100);
// Write the path for the batch accoring to the randomnumber you got
if (randomNumber < 15) setlabel(current,"path",1);
else if (randomNumber >= 15) setlabel(current,"path",2);
This sends the batch in 15% of the cases to port 1 and in 85% to port 2.
To make this work you just use the label at the the Send To Port trigger
mischa_spelt
Actually you can replace your whole code with
setlabel(current, "path", bernoulli(15, 1, 2));
philip_diem
Oh yes you`re absolutely right. Thanks! The more you know 🙂
brandon_tondreault
Thanks guys. This worked in my simulation. It saved me some time trying to figure this one out.
