Multiple taskExecuters work together with taskSequence list
ozawa_shinya
ozawa_shinya
[ FlexSim 23.0.11 ]
I would like to create a model where multiple taskExecutors work together. Is it appropriate to use a task sequence list?
The attached model does not use a task sequence list, but is it possible to recreate the process flow within this model using a task sequence list?
I feel like using a task sequence list won't work, but I can't be sure.
Thanks in advance.
multiple_taskexecutors_work_together.fsm
jason_lightfootVL7B4
ozawa_shinya
Yes I read that, and there is no mention of taskSequence "list" there, does this mean it can't be done with taskSequence list?
The standard picklist option to push the task sequence to a list will be the regular transport sequence. However you should be able to create a coordinated task sequence and push that to the list. For examples on creating coordinated tasks look under the transport pick options. The key commands used are:
  • createcoordinatedtasksequence()
  • insertallocatetask()
  • insertproxytask()
  • insertsynctask()
  • insertdeallocatetask()
  • dispatchcoordinatedtasksequence()
Jeanette_Fullmer
Hi @Shinya O, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
ozawa_shinya
Thank you for your information. I found that it seems possible to create coordinate tasks by using these commands. First, I will check the transport pick options.
