Creating child tokens from label / Batching label
KhadijaM
KhadijaM
[ FlexSim 23.1.1 ]
I have a model (see attached model and picture to further explain) of trolleys entering an autoclave. The total number of trolleys is specified for each individual product and assigned as a label. The challenge I'm having is that the autoclave can only take 6 no. trolleys at a time. How can I take the total number of trolleys and release only 6 at a time to the autoclave?
Kind regards,
Khadija
Vinay_S_Jindal
Hi @KhadijaM,
I modified your model, I added a subflow and moved Autoclave delay time inside it.
Check this modified model solves your problem.child-token-and-label-query Mod.fsm.
Also check the formula I used to consider no of child tokens to be released to subflow.
KhadijaM
Thank you so much Vinay this is exactly what I was looking for!
KhadijaM
Just an additional question.
The time taken for the autoclave time now is applied to each of the trolleys.
What I mean is if I have a token A where the total autoclave time is 36hours, this means that it requires 6 loads of the autoclave at 6hours each. By dividing the total autoclave time by 6 do I achieve this?
Note that each unique batch has a unique autoclave time. Meaning that token B with a total autoclave time of 40hrs will have 6.6hours and 7 loads.
Kind regards,
Khadija
moehlmann_fe
You'd simply divide the total time by the number of batches which you already determine as the number of subflow tokens.
Note: Instead of the expression @Vinay S used for that, you can also just use Math.ceil(token.Trolleys/6).capture1.png
KhadijaM
I understand, thanks so much Felix!!
