Monitoring model triggers OnRunStop
zhun_z
zhun_z
[ FlexSim 21.2.4 ]
Monitor model OnRunStop.fsm1.gifExcuse me, i want to monitor the model OnRunStop, i build two same activity with the same PF, Why the no.1 cann't monitor the model OnRunStop, but no.2 can monitor sucessfully?Monitor model OnRunStop.fsm
Ben_WilsonADSK
This looks like some limitation in the current version of the software. As you found, one Process Flow Wait For Event activity can successfully detect the OnRunStop event. In addition to that, the OnRunStop Model Trigger found in the Toolbox will also run when you stop the model.
As a work around you can do something like the following with a single Wait For Event activity:
I tested this setup and found that it works properly - both Custom Code activities execute their behavior.
joerg_vogel_HsH
OnRunStop event is a final last single call before all activity ends. If there would be a multiple event detection a procedure of your model must run beyond the point of stop in an encapsulated environment. Only if these procedures stop by design, you can start your model again. Such an exclusion makes it difficult to run multiple scenarios in an experimenter. if you like to implement a pre-stop or a general trigger over your whole model you can change a watched and tracked variable in your model. Whenever you set a value of this variable somewhere in your model, you can detect it in a central logic.
zhun_z
Thank you ,I will try to follow your proposal.
zhun_z
Thanks, tracked variable is a new idea, i will try it.
