Making multiple AGVs following the same logic
oaljarrahBEV2F
oaljarrahBEV2F
So, I have this model and I’d like some guidance on the following:
  1. Is there a way to make all TaskExecuters (AGVs) follow the same logic without rebuilding or copying the entire ProcessFlow every time, especially when using the Experimenter?
  2. Is it possible to use custom functions instead of the default FlexSim energy-consumption settings for AGVs? For example, can I model recharging (regenerating energy) and make energy usage depend on speed and distance traveled?
  3. How can I display the AGV’s state of charge (SOC) on the dashboard?
FelixMoehlmann
1. This is what Object Process Flow are for. They run one instance of the flow per linked object, making them a good choice for scalable logics.
https://docs.flexsim.com/en/25.2/ModelLogic/ProcessFlowBasics/TypesOfProcessFlows/TypesOfProcessFlow...
2. You can build your own battery system using Tracked Variables. An example can be found in the linked post.
https://forums.autodesk.com/t5/flexsim-forum/agv-power-draw-during-acceleration-at-max-velocity-and/...
3. You can use a simple Statistics Collector that feeds a bar chart to show the battery level. See attached model.
