Limit the items on a gravity flow rack
Gust_Flex
Gust_Flex
[ FlexSim 23.1.2 ]
I want to limit the items in my gravity flow rack. I only want to items per slot in my rack. I tried to customize the code of "Slot Assignment Strategy" but it didn't work:
1712327425506.pngCan someone help me?
FelixMoehlmann
Did you add the "items" label to the slot. Because that's not a default expression. Other than that the code looks like you are trying to count the amount of items of a specific type in the slot. But due to the matching labels condition items with a different type can't be in the slot in the first place, no?
You can check how many items are assigned to a slot through the slotItems property of the slot class. So to limit the total quantity per slot you would just add "slot.slotItems.length < 2" to the condition.
Gust_Flex
If I add the "slot.slotItems.length <2" it still doesn't work.. here is my testfile.
test-simulation-flowrack-fm.fsm
FelixMoehlmann
The slot is assigned in Process Flow, so that's where you have to add the condition.
Jeanette_Fullmer
Hi @gust-flex, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
