Limit number of proccesses per day/shift on a processor
ana_pc2
ana_pc2
[ FlexSim 20.2.3 ]
Hello everybody!
How are you?? My question is that I am trying to code a restriccion that limits the number of operations per day on a processor. In other words, I want to have a processor that only does 2 processes per day or shift (there is only 1 shift per day, so I don't mind). But I can't think in any logic to make that restriccion works. Any suggestions?
I tried a pull strategy with pullitem() only if the variable with the content on that day on that processor (I keep the date in another variable to check) is not higher than 2, but in some point stops working well 😞
If I don't put any processes limit per day, it works perfectly the pullitem logic... 😧 so I am missing something -.-
Thanks!
jeff_nordgren
Hi @ana.pc2,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
Thanks.
marcello_rosadini
Hi Ana,
you can try some variation of the attached model. In this one, the processor will process 2 jobs in 1 hour, randomly spacing the jobs within the hour.
Hope it helps!
support altran_1.fsm
joerg_vogel_HsH
  • You choose randomly three values by statistical distributions.
  • You sum the values to get a base of 100%.
  • Then you compute the percentage of each randomly chosen value to the base of 100%.
  • This percentage value multiplied by your time interval value gives you the first and second arrival time at your processor.
You must delay the entry time to your processor by another processor or simply in a Process Flow activity
Ben_WilsonADSK
Hi @ana.pc2, was Jörg Vogel's or marcello.rosadini's answer helpful? If so, please click the red "Accept" button on one of their answers. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept or comment back to reopen your question.
