Lift speed of AGVs
Lift speed of AGVs
luis_rodrigues
Message 1 of 8
Lift speed of AGVs
luis_rodrigues
[ FlexSim 24.1.0 ]
Hi, I'm working on a model that works with AGVs, is there a way I can introduce "lift speed" to the AGVs as if they where normal forklifts?
I thought of using just regular forklifts but I want them to look similar to the AGVs
mlall-agv C1.fsm
Replies (7)
Message 2 of 8
joerg_vogel_HsH
You can replace an AGV by a transporter. Edit. It is up to you to adjust a shape as you like. I would start to set unnecessary components in a animation creator to be invisible.
Message 3 of 8
luis_rodrigues
In the model you can see that I already changed to "normal transporters" how can I shape it as an AGV?
@Felix Möhlmann can you give me a hint?
Message 4 of 8
FelixMoehlmann
The transporter consists of multiple surrogate objects, so they can be animated independently from each other.
As Jörg said, I would start by going into the animation editor (right click -> Edit -> Animations) and hide/change some of those shapes.
Replacing the "Truck" shape with the AGV model and hiding the "Man" ends up like what you see below, for example.
Message 5 of 8
luis_rodrigues
Thank you for your answer @Felix Möhlmann, mine is getting like this:
The other elements don´t change. Should I sized them to match the body?
Message 6 of 8
FelixMoehlmann
The components will adjust their size based on the size of the main object on reset. See the "Scale _ with" options in the lower right.
Message 7 of 8
luis_rodrigues
Thank you
Message 8 of 8
logan_gold
Hi @luis-rodrigues, was one of Felix Möhlmann's or Joerg Vogel's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
