Large simulation model best practices
arunTTT2P
arunTTT2P
[ FlexSim 16.0.1 ]
I need information regarding best practices in building a large simulation model. In other words, best practices to build a RAM optimized simulation model.
Ben_WilsonADSK
There was this post along the same topic in the FlexSim blog:
https://www.flexsim.com/lessons-from-a-massive-model/
Some other memory-related considerations:
  • combine flowitems using join rather than pack whenever possible (minimizes number of flowitems)
  • create flowitems only when they are needed and destroy them as soon as possible (minimizes number of flowitems)
  • if flowitems do need to persist (or data related to flowitems), consider abstracting flowitems into rows of a bundle and only spawn "physical" 3D flowitems when needed
Other tricks for limiting RAM usage will be more on a case by case basis, depending on what your modeling, the approach you take, the inputs driving the model, and the required outputs.
But in general, a massive number of flowitems is usually where models can become unwieldy. The suggestions above could help.
nmzenke
@Ben Wilson
Is there an way to track the number of flowitems that are currently in play within a model over the course of a simulation run? Is that information stored in some variable? If so, I can write that value to a tracked variable every so often and plot that over time.
Ben_WilsonADSK
Hi @Noah Zenker,
For new questions, please post them as new questions. This thread already has a marked answer.
Please also see the best practices for using this Answers site to better understand the nature of a Question & Answer site, which differs from an old-school forum in regards to having a top question, answers to said question, and related comments.
See points 14 and 15 in particular for tips on the right place to ask a new question.
Thanks!
