For loop to find largest number in table column.
kari_payton
kari_payton
[ FlexSim 17.2.1 ]
I need help writing a code that finds the highest value in a table's column. Here's my attempt but it returns a 0.
Table MainData = Table("MainDataTable");
int oldResult = 0;
int newResult = 0;
for( int row = 1; row<= Table("MainDataTable").numRows; row++)
	newResult = Table("MainDataTable")[row][1];
	if (newResult >= oldResult)
		oldResult = newResult;
return newResult;
Matthew_Gillespie
You need to return oldResult, not newResult, since that is where you're storing the current biggest number.
Matthew Gillespie
FlexSim Software Developer
kari_payton
@Matthew Gillespie
I tried that but still get a 0.largesttablenumhelp.fsm
Matthew_Gillespie
You need to put braces around everything you want the for loop to do, otherwise it just executes the first line over and over.
int maxValue = 0;
for( int row = 1; row <= MainData.numRows; row++) {
	int curValue = MainData[row][1];
	if (curValue > maxValue)
		maxValue = curValue;
return maxValue;
(I renamed your variables for clarity)
Matthew Gillespie
Matthew_Gillespie
You could also do this very easily with a query:
return Table.query("SELECT * FROM MainDataTable ORDER BY [Col 1] DESC")[1][1];
Matthew Gillespie
kari_payton
ok got it. Thanks @Matthew Gillespie
mischa_spelt
Or, if you prefer not to use queries, you can use the findmax command (for more information, look it up in the command reference). For example, the following code assumes that you have a global table MyTable and want to find the maximum value in column 2:
Table table = Table("MyTable");
int maxOfColumn = 2;
// Returns the maximum value
return findmax(table.numRows, table[count][maxOfColumn]);
You can use the optional third parameter to return something else, for example if you want to know in which row the maximum occurs
// Returns the row containing the maximum value
return findmax(table.numRows, table[count][maxOfColumn], count);
