Label does not exist Err
solidworksan
solidworksan
[ FlexSim 19.0.0 ]
TTP_set pos.fsm
hi
At onEntry, I checked the stock status of the rack in the global table, and put Num (Rack number) and Level (Rack height) label values in the box to create a process to put it in the rack location I intended.
But I don't know the cause and solution of the above error "Label does not exist"
Can you help?
FelixMoehlmann
Hi @Solidworksan,
your racks are set to send the items out based on the non-existant "Type" label. Either create this label (but this will lead to another error as the racks currently don't lead to any other objects) or choose a different, appropriate option for the "Send To Port" setting (for example "First Available").
SimFlex_support
@Solidworksan
The racks have not any output objects and you set the sendtoport.
It's the problem. I fix it.
And I set the Num and Level value in Source Oncreation trigger.
I attach the fixed model.
If you have any questions about this, make me know it.
ryan_c10
Hi @solidworksan, was one of David Seo's or Felix Möhlmann's answers helpful? If so, please click the red "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
