Is there a way to sum the values stored in labels?
kari_payton
kari_payton
[ FlexSim 16.1.0 ]
I tried doing something like sum(Label: 'labelname' + Label: 'labelname2') to see if it would output the value. The labels have value 10.5 and 6.76.
Matthew_Gillespie
You'd want to use code like this:
double sum = getlabel(token, "labelname1") + getlabel(token, "labelname2");
Matthew Gillespie
FlexSim Software Developer
Matthew_Gillespie
The Label: myLabel syntax is just a shortcut for getlabelI(token, "myLabel") and can only be used by itself in a Universal Edit field (blue bordered fields in Process Flow).
Matthew Gillespie
