21.2 Update:
There's now a ProcessFlows property that can be used with the Object.setProperty() method.
obj.setProperty("ProcessFlows", "ObjectFlow"); // Attach obj by name reference
obj.setProperty("ProcessFlows", processFlow); // Attach obj by node reference
*Note that this method will detach the object from any other flows it may be attached to that aren't passed into the setProperty method.
You can attach the object to multiple flows by passing in an array:
obj.setProperty("ProcessFlows", ["ObjectFlow", "ObjectFlow2"]);
You can also pass a null value to detach the object from all flows:
obj.setProperty("ProcessFlows", 0);
Original Answer:
function_s(processFlow, "attachObject", obj)
where processFlow is a pointer to your process flow object and obj is the object you want to attach.
Matthew Gillespie
FlexSim Software Developer
