Is it possible, via Flexscript, to change the skin and hair color of the basic operator?
guiroehe
guiroehe
Is it possible, via Flexscript, to change the skin and hair color of the basic operator (OperatorMaleStanding, OperatorFemaleStanding)?
If so, how?
Thank you.
moehlmann_fe
For skin texture: Yes, you can use "changepersonvisuals(object, "Skin", index)" for the basic operator as well.
https://docs.flexsim.com/en/25.2/Reference/CodingInFlexSim/CommandReference/Commands.html#changepers...
For hair: Not really. The basic operator has a fixed hair texture with a set color. The most you can do here is to change the "Diffuse Color". But this is a lot more complex to do in code and the effect is minimal. If you want proper different hair colors (and styles) you would need to use a person object from the people module.
guiroehe
Thank you very much, @moehlmann_fe .
This confirms what I was getting as a result: no changes on hair color.
Thank you.
