Invalid row number
Invalid row number
cho3
Message 1 of 12
Invalid row number
cho3
[ FlexSim 22.2.0 ]
時間:0.000000 異常:FlexScript 異常:無效行號:4 in <no path> at MODEL:/MC5>variables/setuptime
時間:0.000000 異常:FlexScript 異常:無效行號:4 in <no path> at MODEL:/MC5>variables/cycletime
不知道怎麼解決
Replies (11)
Message 2 of 12
FelixMoehlmann
The error message says "in <no path>" meaning the table you are trying to read from does not exist. Check if the table name is correct in the setup and process time settings.
If that doesn't solve it, we will need more information. It would be best if you could upload the model.
Google translation:
錯誤訊息顯示“in <no path>”,這表示您嘗試讀取的表不存在。檢查設定和處理時間設定中的表格名稱是否正確。
如果這不能解決問題,我們將需要更多資訊。如果能上傳模型就更好了。
Message 3 of 12
cho3
Message 4 of 12
FelixMoehlmann
As I expected, the table name in the setup time and process time settings is wrong. The table is called "processor" not "professor".
Additionally you have to toggle the table columns that contain a statistical distribution expression as flexscript.
And in the "MC4" list you have a comma instead of a dot between "value" and "Type".
正如我所料,設定時間和處理時間設定中的表名是錯誤的。該表被稱為“處理器”而不是“教授”。此外,您還必須將包含統計分佈表達式的表格列切換為 Flexscript。在 MC4 清單中,value 和 Type 之間有一個逗號而不是點
1050087-2_1.fsm
Message 5 of 12
cho3
1050087-2_autosave.fsm
it's still not work....
Message 6 of 12
FelixMoehlmann
I can't see any differences between that model and the one you uploaded earlier. Please take a look at the model I attached to my previous comment. It contains fixes for all issues I could find.
我看不出該模型與您之前上傳的模型之間有任何差異。請看一下我在之前的評論中附加的模型。它包含我能找到的所有問題的修復。
Message 7 of 12
cho3
I already checked the dot and flexscript.But still
time: 0.000000 exception: FlexScript exception: Invalid row number: 4 in <no path> at MODEL:/MC5>variables/setuptime
time: 0.000000 exception: FlexScript exception: Invalid row number: 4 in <no path> at MODEL:/MC5>variables/cycletime
time: 0.000000 exception: FlexScript exception: Invalid row number: 1 in <no path> at MODEL:/MC4>variables/setuptime
Message 8 of 12
cho3
Message 9 of 12
FelixMoehlmann
In the lastest model you uploaded the table name in the processor's setup time and process time is still "Professor", not "Processor".
Message 10 of 12
cho3
1050087-2.fsm
after i checked everything,there is a new problem!
Message 11 of 12
FelixMoehlmann
Yes, I forgot to mention this. You should check the "Row" and "Column" expressions as well. In the screenshot in my previous comment you can see that the "Row" is set to 4, but the tables all only contain two rows.
Based on the column names it should be set this like.
But I can't be sure if that's correct. The "ProcessTime" tables contain the same information so I don't know which ones should be used.
Message 12 of 12
logan_gold
Hi @cho, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
