Input Process / contraint on a process
juliette_c
juliette_c
[ FlexSim 19.0.3 ]
In my model, there is a combiner named " Ligne Lot Panaché" which needs 4 references in order to produce a new reference.
But there is a contraint on the combiner :
If the sum of the 4 references inside the system is < 1000
then the combiner is stopped all the week
The 4 references are stocked inside the racks CA , DA and DB.
The sum needs to delete all the references that are used for the process .
If you have an idea to contraint the combiner !simu.fsm
sebastian_hemmannE3JAU
I think I would create a token that checks once a week if the sum of parts in the racks of your System is >= 1000 and if not closes the Input Ports of the Combiner. If it is with the next check, open the port again.
Just find what I mean in the attached Model.
19301-simu-sh.fsm
juliette_c
Thanks it help me a lot
The 4 references that the combiner are the Item Type = 81,82,83,84 and would like to check only those ItemType in the different rack
Is it possible to specify that?
Attached the solution, I would do. But it seems as if you have to try out using Process Flow to go on with your project on your own;-)
19305-19301-simu-sh2.fsm
