Importing DWG files in 2023
BGaskins8Y6PT
BGaskins8Y6PT
[ FlexSim 23.0.0 ]
I am unable to use models with imported DWG files in version 2023.0.0. There were no issues in 2022.2.3. When I try to open these models in 2023, the model fails to open, or I am unable to select a 3D object in the model view.
Has anyone else seen this problem? I did not find anything in the 2023.0.0 or 2023.0.1 release notes.
Thanks.
SimFlex_support
Another issue about 2023's importing dwg file...
It's FlexSim automatic exiting after importing autocad dwg file and UNCHECKing 'No Select'.
FlexSim application exits self-automatically.
Something is wrong in FlexSim 2023's dwg file importing.
Please check it.
jason_lightfoot_adsk
I've confirmed this using the supplied drawing 'ER_small.dwg' and will send in a report.
Thank you for posting the problem.
Matthew_Gillespie
@Bob G This bug has been fixed for 23.0.2 which will be released later this week.
Matthew Gillespie
FlexSim Software Developer
BGaskins8Y6PT
That's good!. Thank you for the update.
emion
Community Visitor
Community Visitor
I have tried a few times to place a DWG file into FlexSim with no success...  can you give me a little instructions?
