If Statement
If Statement
sudheer_r
If Statement
sudheer_r
[ FlexSim 20.0.0 ]
Is there any difference between the below if statements
Whats the difference between this two
if (2&&4==2&&4) {
	/*Statements*/
if (2==2 &&4==4) {
	/*Statements*/
Matthew_Gillespie
They're very different.
2==2 && 4==4
This is comparing the two values on the left and the two values on the right and then ANDs the results together. So this statement is only true if both values on the left are the same and both values on the right are the same.
2 && 4==2 && 4
Because of the order of operations this will compare the two values in the middle first. If this is false then the whole statement is false. Otherwise it will AND that value with the values on the far left and right. If both of those are also true then the whole statement will be true.
Matthew Gillespie
FlexSim Software Developer
