I want to set location of object on rack like this, What should I do?
thawatchai_p
thawatchai_p
[ FlexSim 19.0.0 ]
Hello, please help me to do this. I want to set location of object on rack like this.Please sending me your file. @Jeff Nordgren @Matthew Gillespie @Cliff King @Joseph Gillespie
joerg_vogel_HsH
The rack object is in FlexSim 19.0 still classic. You have to go through the input process of this object to put items in the rack. You find in the properties window the tab rack. There are two functions responsible for placing items into the rack
  • Place in Bay
  • Place in Level
If you get a more familiar with FlexSim, you’re seeing in the source code that those functions returns number values for bay and level. You have to transfer the data for bay and level, when the item enters the rack into those functions or you choose the templates from the picklist of each function, which do the placing.
Edit:
place-in-rack-by-expression-of-label.fsm
zac_h_adsk
Did Jorg's response answer your question? If so please accept his answer, thanks.
