I have logic issue
I have logic issue
dupapupa
I have logic issue
dupapupa
[ FlexSim 23.1.0 ]
Hi, I've been struggling with a problem for about a week now. It's completely simple and relies entirely on logic, but I seem to be having some trouble.
Basically, you have 3 sources and each of them creates an item (task) with its own type A, B and C. They go into one queue and then into the processor. Tasks of type A and B (yellow and green, respectively) can be processed by the system's processor simultaneously in the amount of up to 5, but provided that there is no task of type C (red) on the processor at the moment. In this case, they must wait until the task of type C finishes its processing.
In turn, tasks of type C require that the processor is free from other tasks. If there is something on the processor, then this task must wait until all tasks on the processor have completed their processing.
As you can see, these conditions are mutually exclusive and still simple, but I got stuck at the stage of implementing them in the model. I tried to use messages, but everything turned out to be quite laggy and did not work as required by the conditions.
Any help, hints or suggestions will be much appreciated.
My model so far (i can't upload model , so here is link to drive): https://drive.google.com/file/d/1MBnKpXZq_Uh7MKojmFh1okaJHSRjl_io/view?usp=sharing
FelixMoehlmann
There are likely many other possible solutions, but here is one I find relatively straightforward and 'elegant'.
The queue is set to not release items by itself. The items will instead be released to the processor by a Process Flow. In this Process Flow an Event-Triggered Source listens for items entering the queue. Depending on the type of the item, the token is assigned a 'weight' of either 5 (type C) or 1 (other types).
Before the token releases the item it has to enter a zone. A subset is defined for this zone that includes all tokens and limits the content by the sum value of the "weight" label (Subset Constraints). So either one type C token can enter or up to five other tokens. The token then waits for the item to exit the processor and then leaves the zone.
zone-subset-limit.fsm
If the items should be processed in FIFO order (type A and B items can't overtake type C), activate the "Enforce Queue Order" option on the Advanced tab of the zone settings.
dupapupa
Wow, it actually works! To be honest, i am not particularly into Process Flow, but this concept with subset zone and weights is pretty elegant, as you said, and easy to understand. Thank you! One thing i don't really get is those "breath" sections with zero time delay, but I don't think they matter much, right?
FelixMoehlmann
They are there to make sure that any internal logic of the queue and processor have finished before an item is released to the processor.
They probably are not necessary here, you are right. But experience has taught me to err on the side of caution when it comes to timings in FlexSim.
