How to use variable column name in SQL query?
rajankur6494
rajankur6494
[ FlexSim 23.1.1 ]
Hi Team,
I am trying to pass the variable column name in SQL query, but it is not working as expected. This is first time when I am using variable column name instead of column values. Here, I am assigning Week as variable value to column and using SUM formula over it.
Is this syntax correct?
Could you help me to resolve it?
Thank you!
joerg_vogel_HsH
I do not know, but
string Week = "Wk_1";
string qstr = "SELECT SUM("+Week+") FROM GlobalTable1"; Table result = Table.query(qstr);
this works.
rajankur6494
Thanks! @Joerg Vogel
It is working.
