how to use operator to separate flowitems from the pallet
pruthvi_r1
pruthvi_r1
[ FlexSim 17.1.6 ]
pick-up-boxes-only-by-alpha.fsm Hi,i want operator(Alpha) to pick boxes from the pallet and he should not pick pallets to transfer them to thier respective conveyors.
i want him for only box picking task but once he finished picking boxes then he is going for pallet picking and i don't need that.
thank you
jeff_nordgren
@Pruthviraja M
What you need to change is the Use Transport field in the Separator Properties window.
I believe that this should give you the results that you are looking for.
Thanks.
pick-up-boxes-only-by-alpha-jn1.fsm
