How to set two way path?
Junna
Junna
[ FlexSim 23.0.4 ]
I would like to set two different path from source to "開梱場1" and "開梱場2" by using imported excel data into source.
Each item should be transported to either "開梱場1" or "開梱場2"
In Excel, one column called "X" has either KIT or SET correspond to item name in row.
How can I assign SET/KIT items transport to their correct queue?
Creating label X - SET and X - KIT each queue but it did not work.
Sorry if my explanation is unclear, but hope to get an answer.
Thank you.
moehlmann_fe
You can use the "Port By Case" option in the "Send to Port" field of the source to determine which port the item is send through depending on some value (in your case the label "X").
Junna
Thank you for your quick response! It worked! Really appreciate your help.
