How to set operator time tasks to 0
zan_k
zan_k
[ FlexSim 19.1.0 ]
v1.fsmHello
I have a question how to delete the time of operator to move from queue to processor. I would like that simulation is done strictly with the time that was defined in the process flow (Delay task
Below on the attached picture is my problem. I want to exclude the time because of 3D model.
Thank you!
Attached my simulation
jeff_nordgren
@Zan K
You are in the right area. Just below where you have circled in your graphic is a field called Rotate while traveling and the drop down field option to the right of that field. Just change the drop down field to "Do No Travel Offsets" That way the operator will not travel to/from an object to load/unload it. Which will then not create that time that you are referring to.
If you have questions, please let us know.
Thanks.
