How to selectively Pull from from using Label Array?
jkhedekar
jkhedekar
[ FlexSim 23.0.15 ]
I have 2 lists. One which keeps track of parts it has created. It has a label column called PartName.
Second list is parts requested by operator which also has a label column PartName.
When the a value it pushed in second list as a request by operator it triggers the flow.
The flow starts with a pull request from first list which pulls one value and Assign to token.requestpull
The flow moves to a batching step where I batch 3 token with a max wait time of 60 sec. I also track how many were batched before getting released
In batching process flow for label aggregation I have
From Label - requestpull.Partname
To Label - requestpull
Aggregation - Make Array
Then I want to pull from first list. The request quantity of pull from first list is the number of token I have batched which is store in label batchCount (this works right) I have puller token for second list as pullerrequest
For query I only want to select parts which are requested by operators so
WHERE PartName IN pullerrequest.requestpull
This however does not work and shows sql query mistake. Where am I making a mistake?
joerg_vogel_HsH
Try IN clause argument with brackets.
pullerrequest.requestpull datatype must be an array. Elements of this array must match with PartName. Print arguments into an output console for testing.
look for examples in https://www.w3schools.com/sql/sql_in.asp
jkhedekar
Got a work around but it works now. Thanks!
Jeanette_Fullmer
Can you share your solution and accept it?
jkhedekar
You can create assign a label called NameArray and in values select Array and Set Array. In that portion added the following as code.
Array values = Array(arraySize);
for(int i=1; i<=arraySize;i++){
values = token.requestpull.PartName;
return values;
jkhedekar
I don't think I can accept my own answer, I did it though
