[ FlexSim 18.0.4 ]
truck-respecting-nn-space-at-join-point.fsmI have built an example model that showcases the issue I'm having. In a nutshell, I have two sources of trucks traveling down their network path and joining together onto a single network path for the final segments of their travel. I can change the flowitem settings to "..."block space on networks" and make sure the network node paths are "non-passing" but at the join point/node there is overlap of the the executors while they wait to merge onto the joining node.
I have two nearly identical versions of the sample layout in the attached model. My preference would be to use the top example where a stream of trucks from below slowly turn and then merge with the top/horizontal path. Is there a way to make the different trucks aware of the others? I see there are collision settings but I'm not sure what the cleanest way to go about doing this.
