How to Prevent AGV Deadlock on a Single Bidirectional Path?
hbg485
hbg485
My current model uses two AGVs on a single bidirectional path.
The layout consists of one Source and 11 Processors. A deadlock occurs between an AGV traveling from a Processor back to the Source and another AGV traveling from the Source to a Processor.
I tried creating a Control Area, but it is not efficient. What I would like to implement is a logic where, before a deadlock occurs, an AGV following another AGV diverts to a red control point (like a side lane), waits until the other AGV passes, and then continues moving.
Do you have any ideas on how this could be achieved?
support5CRPZ
You can solve your issue of collision dead lock using 'Control Area' library.
But you will meet the same issue below area.
When you will use one pass line of bidirection, you can't avoid the dead lock issue in the case of like that pass line.
You will make a customized logic or bypass line of the area of collision.
email ID : support@flexsim.co.kr & support@simflex.co.kr
hbg485
Could you provide any practical examples, for instance by using the Agent System?
support5CRPZ
I already attached the solved model by me.
hbg485
@moehlmann_fe I would appreciate your help with this issue.
