How to load and reference container objects in task executer?
SamYates
SamYates
[ FlexSim 24.0.2 ]
I have created a model and attached it. I have created a task executer that has 16 container objects in it and is connected to an operator. In this model I am attempting to pick from different SKUs (Rack locations) and load each container with a given number (can vary by container) of SKUs. I have currently run into an issue in which only 4 of the containers are loaded and with different SKUs. How can I change this model to accomplish my goal?
Some more specific questions are listed below:
- How can you reference a specific list of containers that need to be filled for a given SKU (box)?
- How can you reference all of the boxes in one container?
- How can you reference a container (totes) capacity?
Thank you.SmartCartOfficialTemplateV2.fsm
jason_lightfootVL7B4
You model stops since idx from the subflow is 5 and you're trying to find an item whose Type is 5 (none exists).
You can refer to objects within objects using
subnodes - where n refers to the rank.
eg you can run this in a script window:
Object op=Model.find("Operator1");
return op.subnodes[3];   //returns the third smartContainer tthe operator is holding
If you want to get all the objects as an array then it's:
op.subnodes.toArray()
to get the boxes in the 3rd Container it would be
op.subnodes[3].subnodes.toArray()
If you have a label on the container called 'capacity' then it's
op.subnodes[3].capacity
