How to import data from global table to empirical distribution table
hhnaing2
hhnaing2
[ FlexSim 23.2.0 ]
I would like to connect to SQL server from the production line to pull the past one month uptime and downtime data of the machine. Upon accessing SQL server, it looks like data will be imported to global table. Then, how to import the data from global table to Empirical table automatically. That means once the model starts running, model connect to SQL sever and retrieve data then data will be imported to global table then empirical table. Would that be possible? if yes, appreciate if you could help to make a simple example model. Thanks a lot.
moehlmann_fe
You can use the code below to copy the table into the distribution. Just replace the distribution and table names so they match your model.
treenode distributionTable = Model.find("/Tools/EmpiricalDistributions/TestName>variables/data");
Table("TestTable").cloneTo(distributionTable.as(Table));
hhnaing2
Where should this code be written? Global table>>on reset>> script edit? Thanks.
jason_lightfoot_adsk
How often do you need it updated? If it's once then just put it in the script console and run it from there.
hhnaing2
I want to update every time the model runs.
If you have other things that might sample the distribution at reset then you should do it either on reset (you may not be able to control the timing of this - it's based on which object you place the code), or you can use a parameter table entry OnSet trigger to run the code which then happens before all reset triggers fire.
