Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
[ FlexSim 23.2.0 ]
I would like to connect to SQL server from the production line to pull the past one month uptime and downtime data of the machine. Upon accessing SQL server, it looks like data will be imported to global table. Then, how to import the data from global table to Empirical table automatically. That means once the model starts running, model connect to SQL sever and retrieve data then data will be imported to global table then empirical table. Would that be possible? if yes, appreciate if you could help to make a simple example model. Thanks a lot.
