How to identify the data type of a label using Flexscript?
nmzenke
nmzenke
Is there a command that will allow me to check the data type (e.g. string, number, array, pointer, etc) of a label that's on a token and/or a 3D object?
joerg_vogel_HsH
moehlmann_fe
object.labels["labelName"].dataType
To know what the numbers returned by this expression mean, you can check the different different DATATYPE_ defines in a script console window. (Simple is generally Array or Map, Coupling is pointer)
nmzenke
nmzenke
Thanks so much. I was trying token.labelName.dataType and getting an error but explicitly putting in the labels["labelName"] worked great. Thanks again
