How to have two operators to move one object using crane?
Lili
Lili
[ FlexSim 23.1.1 ]
I'm working on a case study with large and heavy flow items that need to be moving across the model by a crane and because the items are large two operators must work together at the same time when moving one flow item with the crane. I don't know how to use 2 operators in a crane and I would appreciate any suggestions.
I have a simple model with a dispatcher connected to 2 operators at the end, however I haven't found out how to solve this problem. I will upload the model anyway.
Thanks in advancetest process flow.fsm
FelixMoehlmann
Have you worked through the tutorial on coordinated tasks yet? The example model covered in it looks very similar to what you are asking, so it might help you get to a solution.
Jeanette_Fullmer
Hi @lili,
We haven't heard back from you. Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
Lili
Thanks @Felix Möhlmann
I read the article and it was very helpful. Just what I needed! There are a couple of youtube videos that helped too. I'll share the link below incase anyone is having the same problem.
https://youtu.be/f0FRyr1P1aw
