how to get the results from global table values for each replication?
ahmed_azab
ahmed_azab
[ FlexSim (other) ]
I am using the FlexSim experimenter to get the data from a global table that records 250 data points for each replication.
I used the performance measure parameter "range of global table values". I specified the range from 1 to 250 and the column from 1 to 2. I got the results, but it was in a tree format, not in a table format.
I would like my results to be a table for each replication, showing the 250 values with two columns that are recorded in the global table for each replication.
I am using FlexSim version 5.
joerg_vogel_HsH
In the move the mouse pointer over a node in the tree, where you find your results. Right click your mouse and choose Explore > as Table. Is this a function you are looking for? Otherwise could you please export your results and attach them here a tree-format file.
