How to extract partial object name to refer global table name?
rajankur6494
rajankur6494
[ FlexSim 21.0.10 ]
Hi Team,
I have 10 objects as below:
Obj1_Chair, Obj2_Chair............................................................Obj10_Chair
These objects are having label names as Time_In, Time_Out
I also have global tables related to these objects as below:
Obj1_GlobalTable, Obj2_GlobalTable.........................................................Obj10_GlobalTable
I want to create generic logic for with these object by passing object names (Obj1, Obj2.................Obj10) as loop value.
How can I refer global table name since I have to exclude chair from Object name?
Thank you!
Matthew_Gillespie
There are a lot of different ways to do this. Here are some examples:
String Replace
If you know all the objects end with a specific string you can replace that string with a blank string:
string name = "Obj1_Chair";
return name.replace("_Chair", "");
String Replace with Regular Expression
If you want to generically remove the underscore and any characters after it you can use a regular expression that matches the pattern "an underscore followed by any number of other characters":
return name.replace(/_.*/, "");
String Split
You could also use the string.split() method to split the string into an array of substrings using the underscore as the delimiter:
return name.split("_")[1];
Matthew Gillespie
FlexSim Software Developer
Jeanette_Fullmer
Hi @Ankur A3, was Matthew Gillespie's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
