How to dynamically pass column name into the SQL Query?
asb_praneeth
asb_praneeth
[ FlexSim 17.0.13 ]
Hello
I am trying to write a query in which I want to query certain column of the table based on Item name. This is the following query which I am trying but it is not working
string myName = item.name;
query("SELECT * FROM $1 WHERE [$3] > 0 AND ([Operator] = $2 OR [Operator] = 'AnyOne')"
,reftable("ML1_TaskListTable"),i,myName);
TaskDescriptionPartAPartBPartC
1sdf0.2500.25
2d1.2520
3a003.06
4h31.750
Thanks in advance,
Praneeth Akondi
Jacob_Gillespie
Just insert the string using the + operator:
query("SELECT " + myName + " FROM $1 WHERE [Operator] = $2 OR [Operator] = 'AnyOne'"
,reftable("ML1_TaskListTable"),i);
mischa_spelt
A little safer is
"SELECT [" + myName + "] FROM $1"
in case myName happens to contain a space.
asb_praneeth
Thank you...! It is very basic... ! But I couldnt get it at the time of coding...!
