How to create random alphanumeric string in flexscript?
preetdesai
preetdesai
[ FlexSim 23.1.2 ]
How to generate random string that contains alphanumeric characters with specified number of length of the string. Example are ckd938, jfp393 etc if we need the length of the string to be 6.
carter-walch
Hi @Preet ,
alphanumericDemo.fsm
You could do something like this to make a six digit alphanumeric string randomly. You can adjust the numLetters and numNumbers variables depending on the length of the string you want. Example output below.
string letters = "abcdefghijklmnopqrstuvwxyz";
int numLetters = 3;
int numNumbers = 3;
string result = "";
//append the letters
for (int i = 0; i < numLetters; i++) {
    int randomIndex = duniform(1,26);
    string newChar = letters.charAt(randomIndex);
    result = result + newChar;
    //print(newChar);
//append the numbers
for (int i = 0; i < numNumbers; i++) {
    int randomNum = duniform(0,9);
    string newChar = string.fromNum(randomNum);
    //print(newChar);
print(result);
Hope that helps!
jason_lightfootVL7B4
An alternative:
string result;
Array mix=[3,3]; // 3 letters, 3 numbers
for (int n=mix[1];n>0;n--)
    result+=strascii(duniform(97,122));  // for capitals use 64-90
result+=string.fromNum(duniform(1,Math.pow(10,mix[2])-1),0).padStart(3,"0");
return result;
For both approaches you should add a stream to duniform. If this is to become a user command, pass one in as parameter.
natalie_white
Hi @Preet, was Carter Walch's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
