How to Create a Dashboard Heat Map
stan_e_davis
Message 1 of 10
stan_e_davis
[ FlexSim 22.2.1 ]
I would like to implement a Heat Map data visualization (not A*'s heat map) in a Dashboard but see there is no Heat Map in the library. Is there a way of modifying background cell colors of the Table Chart or similar object in an attempt to replicate a heat map? Something like this...
Thanks - Stan
Replies (9)
Message 2 of 10
Jeanette_Fullmer
Hello @Stan Davis,
You can export your data to Excel and easily add a heat map like this. I do not believe that the cells in a table chart or global are able to add color to them.
Message 3 of 10
stan_e_davis
Yes (the pic is from Excel), but I need to see the data in real 'sim' time and not as a post analysis. I mentioned Table Chart, but I am looking for any ideas on how to emulate a Heat Map with the existing toolset. I am going to request a Dashboard Heat Map be added to FlexSim's features/capabilities. - Stan
Message 4 of 10
jason_lightfoot_adsk
In the meantime Stan, I'm attaching a model with two CustomGUIs that you can point to global tables using the sampler and change the color using the "HeatPallet" color pallet. The global variable maxHeat sets the top threshold.
To open this just right click the "HeatTable" objects in the Toolbox section marked "Graphical User Interfaces" and select "Show GUI". To switch the table use the sampler to select from the list of tables in the toolbox.
The two examples use a different technique to set the background color.
TableCellColor.fsm.pdf
Update: it seems the attributes needed are documented here.
Message 5 of 10
stan_e_davis
Excellent!! That works for me. Really appreciate the support Jason. Thanks - Stan
Message 6 of 10
martin_k5
would it be possible to attach the corresponding model?
Thank you,
Martin
Message 7 of 10
FelixMoehlmann
The model is attached. At the time the forum had a problem where it wouldn't allow .fsm attachments. A workaround was to change the file ending. Just rename the file back to fsm.
Message 8 of 10
martin_k5
Thank you, that works well.
Message 9 of 10
martin_k5
I would have a question regarding your post. I really like this possibility, but I would like to ask if there is a documentation regarding the style attributes as shown below?
Thank you,
Martin
Message 10 of 10
Jeanette_Fullmer
Hello @Martin K5, Since this question already has an answer please start a new post for your question. You can reference this post in your new post.
